소개
This guide is used when the toggle button is no longer functioning properly. If you are experiencing a loose or broken toggle button it must be replaced to keep the device operating normally.
필요한 것
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Use the angled tweezers to disconnect the toggle button covering.
거의 끝나갑니다!
결론
