주요 콘텐츠로 건너뛰기
Eco X Gear Battery Replacement
필요한 것
  1. Eco X Gear Battery Replacement, Frame: 1 단계, 이미지 1/1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: 2 단계, 이미지 1/1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: 3 단계, 이미지 1/1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: 4 단계, 이미지 1/1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: 6 단계, 이미지 1/2 Eco X Gear Battery Replacement: 6 단계, 이미지 2/2
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: 7 단계, 이미지 1/1
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: 8 단계, 이미지 1/1
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: 9 단계, 이미지 1/1
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Lipsett
회원 가입일: 03/20/17
625 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S9-G3, Martin Spring 2017 UMass Dartmouth, Team S9-G3, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G3
2 회원들
안내서 6개 작성하였습니다
댓글 3개
Where to get the new battery?
James Chen - 답글
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 39
전체 시간: 723
