주요 콘텐츠로 건너뛰기
Eco X Gear LED Display Replacement
필요한 것
  1. Eco X Gear LED Display Replacement, Frame: 1 단계, 이미지 1/1
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear LED Display Replacement: 2 단계, 이미지 1/1
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear LED Display Replacement: 3 단계, 이미지 1/1
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear LED Display Replacement: 4 단계, 이미지 1/1
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear LED Display Replacement, LED Display: 5 단계, 이미지 1/1
    • Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
  6. Eco X Gear LED Display Replacement: 6 단계, 이미지 1/1
    • Insert the new LED light into the frame. Use the solder and soldering iron to reconnect the terminals to the new lights.
결론
James Lipsett
회원 가입일: 03/20/17
625 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S9-G3, Martin Spring 2017 UMass Dartmouth, Team S9-G3, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G3
2 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 8
전체 시간: 149
