주요 콘텐츠로 건너뛰기
Ecovacs DEEBOT D35 Battery Replacement
필요한 것
  1. Ecovacs DEEBOT D35 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Press and hold the tabs on both sides of the battery.
  2. Ecovacs DEEBOT D35 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the Deebot
  3. Ecovacs DEEBOT D35 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the screw attaching the battery housing.
  4. Ecovacs DEEBOT D35 Battery Replacement: 4 단계, 이미지 1/1
    • Inert the new battery casing into the housing.
    • Replace the screw attaching the housing.
    • Replace the batter housing in the Deebot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 02/15/17
475 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G2
4 회원들
안내서 4개 작성하였습니다
댓글 7개
How do you actually take the battery pack out of the casing?
Jonathan A - 답글
Where can i find a replacement battery for deebot model d35
Travis neas - 답글
JonathanA - you don't, it comes complete in the casing and can not be opened.
Kate Oe - 답글
But where can we buy a replacement battery for deebot 35?
Kay Pott - 답글
Where can i buy a replacement battery for D35
Terry Martin
Terry Martin -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 60
전체 시간: 13,966
