주요 콘텐츠로 건너뛰기
Ecovacs DEEBOT D35 Motherboard Replacement
필요한 것
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: 4 단계, 이미지 1/1
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: 5 단계, 이미지 1/2 Ecovacs DEEBOT D35 Motherboard Replacement: 5 단계, 이미지 2/2
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: 6 단계, 이미지 1/3 Ecovacs DEEBOT D35 Motherboard Replacement: 6 단계, 이미지 2/3 Ecovacs DEEBOT D35 Motherboard Replacement: 6 단계, 이미지 3/3
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: 8 단계, 이미지 1/2 Ecovacs DEEBOT D35 Motherboard Replacement: 8 단계, 이미지 2/2
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully disconnect the motherboard from the Deebot body.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kevin McKernan
회원 가입일: 02/15/17
107 평판
안내서 1개 작성함
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 14
전체 시간: 2,716
