소개
The spinning brushes are located on the backside of the DEEBOT D35 on the front right and left edge. These brushes pull dirt to the vacuum where it is suctioned up.
필요한 것
Roll the Deebot over on a flat surface. The brushes will be located on the front with bright yellow connectors.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I get a replacement part for the little gray piece on step 3?
