주요 콘텐츠로 건너뛰기
Ecovacs DEEBOT D35 Vacuum Motor Replacement
필요한 것
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: 1 단계, 이미지 1/1
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 2 단계, 이미지 1/1
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 3 단계, 이미지 1/1
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 4 단계, 이미지 1/1
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 5 단계, 이미지 1/1
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 6 단계, 이미지 1/1
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 7 단계, 이미지 1/1
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: 8 단계, 이미지 1/1
    • Remove the vacuum motor body
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brian
회원 가입일: 02/15/17
475 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-2, Eyestone Spring 2017 USF Tampa, Team 12-2, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G2
4 회원들
안내서 4개 작성하였습니다
댓글 한 개
thanks a lots for the valuable info
sk law - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 16
전체 시간: 8,971
