소개
This guide will show you how to remove a defective vacuum motor on the Ecovacs DEEBOT D35. To replace it, install a new one by follow these steps in reverse.
필요한 것
Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
There is a multicolor wiring harness on the front center. This is represented by the orange circle.
Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
다른 3명이 해당 안내서를 완성하였습니다.
