주요 콘텐츠로 건너뛰기
Ecovacs Deebot 900 Front Bumper Replacement
필요한 것
  1. Ecovacs Deebot 900 Front Bumper Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Front Bumper Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Front Bumper Replacement: 3 단계, 이미지 1/1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Front Bumper Replacement: 4 단계, 이미지 1/1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Front Bumper Replacement: 5 단계, 이미지 1/1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: 6 단계, 이미지 1/2 Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: 6 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Front Bumper Replacement: 7 단계, 이미지 1/1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Front Bumper Replacement: 8 단계, 이미지 1/2 Ecovacs Deebot 900 Front Bumper Replacement: 8 단계, 이미지 2/2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Front Bumper Replacement: 9 단계, 이미지 1/2 Ecovacs Deebot 900 Front Bumper Replacement: 9 단계, 이미지 2/2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Gillian Blumer
회원 가입일: 01/16/20
555 평판
안내서 3개 작성하였습니다
댓글 한 개
Where may I buy the front bumper assembly? I'm trying to replace one for a deebot 901 but the mfg tells me they don't see the part directly.
Chris Khacherian - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 68
30일 전: 217
전체 시간: 9,758
