주요 콘텐츠로 건너뛰기
Edwin the Duck Rubber Heart Power Button Replacement
필요한 것
  1. Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: 1 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement, Rubber Heart Power Button: 1 단계, 이미지 2개 중 2개
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Rubber Heart Power Button Replacement: 2 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully take off the rubber skin.
    • It's important to remember to be patient and not rush. You don't want to rip or damage the rubber skin in then resulting in not having a waterproof cover.
  3. Edwin the Duck Rubber Heart Power Button Replacement: 3 단계, 이미지 1개 중 1개
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Rubber Heart Power Button Replacement: 4 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Rubber Heart Power Button Replacement: 5 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement: 5 단계, 이미지 2개 중 2개
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Rubber Heart Power Button Replacement: 6 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement: 6 단계, 이미지 2개 중 2개
    • Use the J1 bit to unscrew all four 9 mm screws connected to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screws attached to the white plastic plate
  7. Edwin the Duck Rubber Heart Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Lift up the motherboard and speaker and place it away and to the side like you see in the picture
  8. Edwin the Duck Rubber Heart Power Button Replacement: 8 단계, 이미지 2개 중 1개 Edwin the Duck Rubber Heart Power Button Replacement: 8 단계, 이미지 2개 중 2개
    • Unscrew the two black 9 mm screws by using the J1 bit.
    • Remove the damaged rubber heart button and replace with a new rubber heart button.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Michelle Montano
회원 가입일: 10/18/17
116 평판
안내서 1개를 작성함
UW Tacoma, Team S1-G4, Rose Fall 2017 UW Tacoma, Team S1-G4, Rose Fall 2017 회원
UWT-ROSE-F17S1G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 899
