주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Eee Pad Transformer Prime TF201 -- Opening Your Device
단지 전제 조건
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
필요한 것
  1. Eee Pad Transformer Prime TF201 -- Opening Your Device, Opening Your Device: 1 단계, 이미지 1/1
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 -- Opening Your Device: 2 단계, 이미지 1/3 Eee Pad Transformer Prime TF201 -- Opening Your Device: 2 단계, 이미지 2/3 Eee Pad Transformer Prime TF201 -- Opening Your Device: 2 단계, 이미지 3/3
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 -- Opening Your Device: 3 단계, 이미지 1/3 Eee Pad Transformer Prime TF201 -- Opening Your Device: 3 단계, 이미지 2/3 Eee Pad Transformer Prime TF201 -- Opening Your Device: 3 단계, 이미지 3/3
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 -- Opening Your Device: 4 단계, 이미지 1/2 Eee Pad Transformer Prime TF201 -- Opening Your Device: 4 단계, 이미지 2/2
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 -- Opening Your Device: 5 단계, 이미지 1/1
    • Place a plastic opening tool under the black plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 -- Opening Your Device: 6 단계, 이미지 1/1
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron Morland
회원 가입일: 10/06/16
346 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-1, Livingston Fall 2016 Cal Poly, Team 10-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G1
2 회원들
안내서 12개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 102
