소개
Replacement of the external portion lock button may be necessary if the button becomes severely jammed or damaged. Replacing the lock button itself is very simple, and the proceeding steps are fairly easy as well. This is a very doable fix!
필요한 것
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
Orient your device so that the lock and volume buttons and the attached components are on the top left.
Press down on the lock button from the outside of your device using your finger.
Use tweezers to pull the lock button upwards from the inside of the device, while keeping your finger pressed from the outside.
Pull the lock button free from the device and set it aside.
다른 한 분이 해당 안내서를 완성하였습니다.
