소개
Replacement of the external portion volume buttons may be necessary if the buttons becomes severely jammed or damaged. Replacing the volume buttons is very simple, and the proceeding steps are fairly easy as well. This is a very doable fix!
필요한 것
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
Orient your device so that the lock and volume buttons and the attached components are on the top left.
Press down on the volume button from the outside of your device using your finger.
Use tweezers to pull the volume button upwards from the inside of the device, while keeping your finger pressed from the outside.
Pull the volume button free from the device and set it aside.
