주요 콘텐츠로 건너뛰기
Eee Pad Transformer Prime TF201 Speaker Replacement
필요한 것
  1. Eee Pad Transformer Prime TF201 Speaker Replacement, Opening Your Device: 1 단계, 이미지 1개 중 1개
    • Power down your device.
    • Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
  2. Eee Pad Transformer Prime TF201 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Eee Pad Transformer Prime TF201 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Eee Pad Transformer Prime TF201 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the seam near the corner of the device.
    • Slowly slide the tool around the perimeter of the device, gradually prying up the screen.
    • It is normal to hear snaps as the spring clips holding the screen in place are released.
    • It is also normal to hear adhesive separating, as a small amount is used to help secure the screen.
  3. Eee Pad Transformer Prime TF201 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Eee Pad Transformer Prime TF201 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Eee Pad Transformer Prime TF201 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • When the screen is free of all spring clips and adhesive, slowly open the device like a clam shell with the hinge being the left hand side of the device.
    • Do not completely separate the screen from the case by more than a few inches, as they are still connected by three orange ribbon cables.
    • Safely place the device back on the table by laying the screen face down.
    • There will be some slight overlapping of the back of the case over the screen.
  4. Eee Pad Transformer Prime TF201 Speaker Replacement: 4 단계, 이미지 2개 중 1개 Eee Pad Transformer Prime TF201 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the ribbon cable by placing a plastic opening tool under the black plastic tab that is on the opposite side of the port as the ribbon cable.
    • Pry upward until the black tab moves 90 degrees, and gently pull the ribbon cable out of the port.
  5. Eee Pad Transformer Prime TF201 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Place a plastic opening tool under the white plastic tab on one of the ribbon cable ports.
    • Repeat the previous process to remove the other ribbon cable.
  6. Eee Pad Transformer Prime TF201 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
    • The device that we wrote this guide for did not come with a battery, so we cannot include it in our own guide steps.
    • The battery is removed during all repairs to protect against short circuits, shocks, and internal damage to the device.
  7. Eee Pad Transformer Prime TF201 Speaker Replacement, Speaker: 7 단계, 이미지 3개 중 1개 Eee Pad Transformer Prime TF201 Speaker Replacement, Speaker: 7 단계, 이미지 3개 중 2개 Eee Pad Transformer Prime TF201 Speaker Replacement, Speaker: 7 단계, 이미지 3개 중 3개
    • Remove the wires connecting the speakers to the motherboard by pushing the small tab until the connection is broken.
    • This may take some finesse to get out, so be careful.
  8. Eee Pad Transformer Prime TF201 Speaker Replacement: 8 단계, 이미지 2개 중 1개 Eee Pad Transformer Prime TF201 Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to remove the speaker from the back case.
    • There may be some slight resistance due to the glue used to hold the speakers in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David Garcia
회원 가입일: 10/06/16
322 평판
안내서 3개를 작성함
Cal Poly, Team 10-1, Livingston Fall 2016 Cal Poly, Team 10-1, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G1
2 회원들
안내서 12개를 작성함
댓글 한 개
useful information thank you.
tyishian lieu - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 287
