주요 콘텐츠로 건너뛰기
Sew a Ladder Stitch
필요한 것
  1. Sew a Ladder Stitch, Sew a Ladder Stitch: 1 단계, 이미지 3개 중 1개 Sew a Ladder Stitch, Sew a Ladder Stitch: 1 단계, 이미지 3개 중 2개 Sew a Ladder Stitch, Sew a Ladder Stitch: 1 단계, 이미지 3개 중 3개
    • Thread your needle and tie a knot in the end.
    • We're using contrasting thread for visibility, but when it comes time for your repair, you'll want to use matching thread.
    • Drive the needle from the back of the material, just before where the tear starts.
    • Pull the thread taut.
  2. Sew a Ladder Stitch: 2 단계, 이미지 2개 중 1개 Sew a Ladder Stitch: 2 단계, 이미지 2개 중 2개
    • Take a small stitch, going in and out of the material, on one side of the tear only.
  3. Sew a Ladder Stitch: 3 단계, 이미지 2개 중 1개 Sew a Ladder Stitch: 3 단계, 이미지 2개 중 2개
    • Take a small stitch, going in and out of the material, on the other side of the tear, directly opposite of the stitch you just took.
    • Pull the thread taut. This should cinch the material together.
    • If your material bunches, try taking smaller stitches, while ensuring that you line up the stitches on either side of the material.
  4. Sew a Ladder Stitch: 4 단계, 이미지 2개 중 1개 Sew a Ladder Stitch: 4 단계, 이미지 2개 중 2개
    • Continue stitching, switching from side to side as described in step 2 and 3 of this guide, pulling the thread taut after each stitch.
    • Stitch until you come to the end of the tear.
  5. Sew a Ladder Stitch: 5 단계, 이미지 3개 중 1개 Sew a Ladder Stitch: 5 단계, 이미지 3개 중 2개 Sew a Ladder Stitch: 5 단계, 이미지 3개 중 3개
    • One the last stitch, drive the needle through both sides of the fabric, taking as small of a stitch as possible.
    • Slowly pull the thread. As you pull, a loop will form. Draw the needle through this loop, and pull the thread taut.
    • Repeat this step, taking a tiny stitch, drawing the needle through the loop, and pulling taut.
    • Ensure that the stitches are tight, and cut any excess threads.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
119 회원들
안내서 19,526개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 74
지난 30일: 256
전체 시간: 11,502
