주요 콘텐츠로 건너뛰기
How to Sew a Whip Stitch
필요한 것
  1. How to Sew a Whip Stitch, How to Sew a Whip Stitch: 1 단계, 이미지 2개 중 1개 How to Sew a Whip Stitch, How to Sew a Whip Stitch: 1 단계, 이미지 2개 중 2개
    • Align the two pieces of material you will be stitching together.
    • Thread your needle and tie a knot in the end of the thread.
    • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
    • Drive the needle into the bottom layer of material from the back side.
  2. How to Sew a Whip Stitch: 2 단계, 이미지 3개 중 1개 How to Sew a Whip Stitch: 2 단계, 이미지 3개 중 2개 How to Sew a Whip Stitch: 2 단계, 이미지 3개 중 3개
    • Pull the needle through the bottom layer of material.
    • Pull the thread taut.
  3. How to Sew a Whip Stitch: 3 단계, 이미지 3개 중 1개 How to Sew a Whip Stitch: 3 단계, 이미지 3개 중 2개 How to Sew a Whip Stitch: 3 단계, 이미지 3개 중 3개
    • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
    • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
    • Pull the thread taut on the backside of the bottom material.
  4. How to Sew a Whip Stitch: 4 단계, 이미지 2개 중 1개 How to Sew a Whip Stitch: 4 단계, 이미지 2개 중 2개
    • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
    • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
  5. How to Sew a Whip Stitch: 5 단계, 이미지 2개 중 1개 How to Sew a Whip Stitch: 5 단계, 이미지 2개 중 2개
    • For the final stitch, come up from the back of the bottom material once again.
    • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
  6. How to Sew a Whip Stitch: 6 단계, 이미지 3개 중 1개 How to Sew a Whip Stitch: 6 단계, 이미지 3개 중 2개 How to Sew a Whip Stitch: 6 단계, 이미지 3개 중 3개
    • Slowly start to pull the thread taut. As you pull, you will see a loop form.
    • Draw the needle through the loop.
    • Pull the thread taut, forming a knot.
    • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
  7. How to Sew a Whip Stitch: 7 단계, 이미지 1개 중 1개
    • Ensure that the stitches are tight.
    • Cut any remaining thread, and admire your handiwork.
결승점
다른 20명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
89,748 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
119 회원들
안내서 19,526개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 31
지난 30일: 153
전체 시간: 40,802
