주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Eightarc Fusion Logic Board Replacement
필요한 것
  1. Eightarc Fusion Logic Board Replacement, Logic Board: 1 단계, 이미지 2개 중 1개 Eightarc Fusion Logic Board Replacement, Logic Board: 1 단계, 이미지 2개 중 2개
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
  2. Eightarc Fusion Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
  3. Eightarc Fusion Logic Board Replacement: 3 단계, 이미지 3개 중 1개 Eightarc Fusion Logic Board Replacement: 3 단계, 이미지 3개 중 2개 Eightarc Fusion Logic Board Replacement: 3 단계, 이미지 3개 중 3개
    • Make sure not to flex the logic board when removing ribbon cables.
    • Individually remove the seven cable connectors plugged into the logic board by grasping each white plug and gently pulling upwards.
  4. Eightarc Fusion Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips Head #1 screwdriver to remove the two 7.15mm washer head screws from logic board.
  5. Eightarc Fusion Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift off logic board up to remove from the device.
결론
작성자
1다른 기여자 명과 함께
Chandler Stalford
회원 가입일: 02/04/15
101 평판
안내서 1개를 작성함
Cal Poly, Team 17-35, Amido Winter 2015 Cal Poly, Team 17-35, Amido Winter 2015 회원
CPSU-AMIDO-W15S17G35
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 566
