주요 콘텐츠로 건너뛰기
Eleaf iJust 3 Disassembly
필요한 것
  1. Eleaf iJust 3 Disassembly, Eleaf iJust 3 Teardown: 1 단계, 이미지 1/1
    • Specification of iJust 3:
    • Resistance range: 0.1 Ohm - 3.0 Ohm
    • Battery voltage: 3.7V
    • Max power: 80W
  2. Eleaf iJust 3 Disassembly: 2 단계, 이미지 1/2 Eleaf iJust 3 Disassembly: 2 단계, 이미지 2/2
    • Insert stick into vice (attach it to the top part) and slowly pull up by "tube part"
    • Be carefull! If you will pull it too fast and too strong, you can break away battery
  3. Eleaf iJust 3 Disassembly: 3 단계, 이미지 1/1
    • Unscrew two screws on the sides of board.
  4. Eleaf iJust 3 Disassembly: 4 단계, 이미지 1/1
    • Thats all, thanks for your attention
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Szymon Milewski
회원 가입일: 12/28/20
741 평판
안내서 3개 작성하였습니다
댓글 2개
It was very helpful, thank you!
kali1902 - 답글
I don’t think Ifixit should be hosting repair guides for products that can damage your health.
guardian10 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 47
전체 시간: 4,915
