주요 콘텐츠로 건너뛰기
Electric Bike Throttle Replacement
필요한 것
  1. Electric Bike Throttle Replacement, Brake: 1 단계, 이미지 1개 중 1개
    • Before starting to disassemble your electric bike, turn the power off.
    • Remove the 3/32 inch Allen screw.
    • When removing Allen screw, make sure the driver is well seated because they are simple to strip.
  2. Electric Bike Throttle Replacement, Throttle: 2 단계, 이미지 1개 중 1개
    • Locate the throttle Allen screw.
    • Remove the 5/64 inch Allen screw.
  3. Electric Bike Throttle Replacement, Throttle: 3 단계, 이미지 1개 중 1개
    • Slide the Throttle off.
    • When removing the throttle, be careful. Remove it slowly to avoid damaging the wire.
  4. Electric Bike Throttle Replacement, Control Box: 4 단계, 이미지 1개 중 1개
    • Remove the following screws.
    • 2 mm Philips screws.
  5. Electric Bike Throttle Replacement: 5 단계, 이미지 1개 중 1개
    • Open up the control box.
  6. Electric Bike Throttle Replacement: 6 단계, 이미지 1개 중 1개
    • Track the throttle wire.
    • To ensure you don't lose it, you should mark it.
  7. Electric Bike Throttle Replacement: 7 단계, 이미지 1개 중 1개
    • Locate the throttle wire.
    • Disconnect the throttle wire plug from the controller wire plug.
    • Take caution while handling these wires. You can easily damage them.
결론
작성자
2다른 기여자 명과 함께
Ali Al-hamadani
회원 가입일: 10/06/22
145 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 30
전체 시간: 1,403
