소개
Use this guide to replace your Electric Lint Remover's faulty or damaged blade. This guide is specific to the Rolling Lint Remover from the Japanese company Daiso. However, electric lint removers from companies such as Wellco, Smartasin, and Feek have similar designs.
The blades are necessary to remove lint balls from fabrics. A dull blade may make clothing appear worse or simply not perform its function of removing lint and fuzz.
Before using this guide, ensure your Electric Lint Roller's blades are inserted correctly. Before beginning the guide, remove the batteries from the device. To ensure a dull blade or blades is the issue, follow steps 1-3 and quickly inspect if the blades are not loose from the compartment or something else is hindering the blades' rotation.
It is difficult to find a single blade replacement, but feel free to purchase the entire blade compartment that can be found at prices as low as fifty-five cents. This way, a singular blade or the entire compartment may be replaced so the device performs as it was just purchased.
필요한 것
We hope this guide helped you. Happy Fixing!
