주요 콘텐츠로 건너뛰기
Electric Outlet Cover Replacement
필요한 것
  1. Electric Outlet Cover Replacement, Cover: 1 단계, 이미지 1/1
    • Setup a workspace around the damaged/old electrical outlet cover you are replacing.
  2. Electric Outlet Cover Replacement: 2 단계, 이미지 1/2 Electric Outlet Cover Replacement: 2 단계, 이미지 2/2
    • Use the flathead screwdriver to remove the screw from the outlet.
    • Lefty loose-y righty tight-y.
  3. Electric Outlet Cover Replacement: 3 단계, 이미지 1/3 Electric Outlet Cover Replacement: 3 단계, 이미지 2/3 Electric Outlet Cover Replacement: 3 단계, 이미지 3/3
    • Remove the faceplate off of the wall.
  4. Electric Outlet Cover Replacement: 4 단계, 이미지 1/1
    • Now that the faceplate is removed clean up the interior and surrounding area of the outlet.
    • Be cautious as you clean the exposed outlet due to the electric current still running through it.
결론
To make sure the outlet cover is properly installed, try to move the faceplate around and plug in your devices to ensure the outlet still works
다른 2명이 해당 안내서를 완성하였습니다.
Jason Villanueva
회원 가입일: 10/23/20
163 평판
안내서 1개 작성함
CSU Los Angeles, Team S12-G22, Harris Fall 2020 CSU Los Angeles, Team S12-G22, Harris Fall 2020 회원
CSULA-HARRIS-F20S12G22
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 61
30일 전: 254
전체 시간: 7,248
