주요 콘텐츠로 건너뛰기
Electric Stove Burners and Drip Pans Replacement
필요한 것
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: 1 단계, 이미지 1/1
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: 2 단계, 이미지 1/3 Electric Stove Burners and Drip Pans Replacement: 2 단계, 이미지 2/3 Electric Stove Burners and Drip Pans Replacement: 2 단계, 이미지 3/3
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: 3 단계, 이미지 1/1
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: 4 단계, 이미지 1/2 Electric Stove Burners and Drip Pans Replacement: 4 단계, 이미지 2/2
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: 5 단계, 이미지 1/2 Electric Stove Burners and Drip Pans Replacement: 5 단계, 이미지 2/2
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: 6 단계, 이미지 1/1
    • Slide new burner through the receptacle.
    • Reassemble stove after.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Delaney Dorsch
회원 가입일: 03/22/21
190 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 111
전체 시간: 4,210
