주요 콘텐츠로 건너뛰기
Electric Wheelchair Battery Replacement
의료 장비
iFixit과 이 수리 안내서는 의료 기기 제조업체가 보증하지 않으며 제휴 관계가 없습니다.
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 1 단계, 이미지 3개 중 1개 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 1 단계, 이미지 3개 중 2개 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: 1 단계, 이미지 3개 중 3개
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: 2 단계, 이미지 2개 중 1개 Electric Wheelchair Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: 3 단계, 이미지 2개 중 1개 Electric Wheelchair Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: 4 단계, 이미지 2개 중 1개 Electric Wheelchair Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: 5 단계, 이미지 3개 중 1개 Electric Wheelchair Battery Replacement: 5 단계, 이미지 3개 중 2개 Electric Wheelchair Battery Replacement: 5 단계, 이미지 3개 중 3개
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: 6 단계, 이미지 3개 중 1개 Electric Wheelchair Battery Replacement: 6 단계, 이미지 3개 중 2개 Electric Wheelchair Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: 8 단계, 이미지 3개 중 1개 Electric Wheelchair Battery Replacement: 8 단계, 이미지 3개 중 2개 Electric Wheelchair Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: 9 단계, 이미지 3개 중 1개 Electric Wheelchair Battery Replacement: 9 단계, 이미지 3개 중 2개 Electric Wheelchair Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Paige Efting
회원 가입일: 01/19/16
159 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 10개를 작성함
댓글 한 개
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 63
전체 시간: 7,394
