주요 콘텐츠로 건너뛰기
Electrical Wall Outlet Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Electrical Wall Outlet Replacement, Wall Outlet: 1 단계, 이미지 1/2 Electrical Wall Outlet Replacement, Wall Outlet: 1 단계, 이미지 2/2
    • Turn off electrical power from the breaker by switching off the breaker that is connected to the designated area.
    • Check power by plugging in rechargeable device and check if charging. If not charging, power to the wall is off.
  2. Electrical Wall Outlet Replacement: 2 단계, 이미지 1/1
    • Remove the screw from the outlet plate using a flathead screwdriver.
  3. Electrical Wall Outlet Replacement: 3 단계, 이미지 1/1
    • Remove plate from outlet using a Phillips screwdriver.
  4. Electrical Wall Outlet Replacement: 4 단계, 이미지 1/1
    • Remove screws from outlet that are connected to the wall using a Phillips screwdriver.
  5. Electrical Wall Outlet Replacement: 5 단계, 이미지 1/1
    • Remove wires from outlet by gently pulling them out of the outlet and wall.
  6. Electrical Wall Outlet Replacement: 6 단계, 이미지 1/2 Electrical Wall Outlet Replacement: 6 단계, 이미지 2/2
    • Connect wires to new outlet being sure to connected them to their designated port. They are labeled on the back of the outlet with: neutral, ground and hot.
    • Insert wire into the designated port and tighten with Phillips Screwdriver.
    • Neutral Wire- White
    • Ground Wire- Copper
    • Hot Wire- Black
  7. Electrical Wall Outlet Replacement: 7 단계, 이미지 1/3 Electrical Wall Outlet Replacement: 7 단계, 이미지 2/3 Electrical Wall Outlet Replacement: 7 단계, 이미지 3/3
    • Reassemble the outlet as it was removed.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Allison Novelli
회원 가입일: 02/23/16
107 평판
안내서 1개 작성함
Texas Tech, Team 22-4, Rauch Spring 2016 Texas Tech, Team 22-4, Rauch Spring 2016 회원
TTU-RAUCH-S16S22G4
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,219
