주요 콘텐츠로 건너뛰기
Electrohome EAAC475 Button Replacement
필요한 것
  1. Electrohome EAAC475 Button Replacement, Battery: 1 단계, 이미지 1/2 Electrohome EAAC475 Button Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Button Replacement: 2 단계, 이미지 1/1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Button Replacement, Buttons: 3 단계, 이미지 1/2 Electrohome EAAC475 Button Replacement, Buttons: 3 단계, 이미지 2/2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Button Replacement: 4 단계, 이미지 1/3 Electrohome EAAC475 Button Replacement: 4 단계, 이미지 2/3 Electrohome EAAC475 Button Replacement: 4 단계, 이미지 3/3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Button Replacement: 5 단계, 이미지 1/2 Electrohome EAAC475 Button Replacement: 5 단계, 이미지 2/2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
결론
Sohail Khatri
회원 가입일: 02/16/16
201 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 236
