주요 콘텐츠로 건너뛰기
Electrohome EAAC475 Projector Lens Replacement
필요한 것
  1. Electrohome EAAC475 Projector Lens Replacement, Battery: 1 단계, 이미지 1/2 Electrohome EAAC475 Projector Lens Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Projector Lens Replacement: 2 단계, 이미지 1/1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: 3 단계, 이미지 1/1
    • Slowly and carefully move one side away from another without detaching anything on the device.
  4. Electrohome EAAC475 Projector Lens Replacement: 4 단계, 이미지 1/1
    • Detach the projector.
  5. Electrohome EAAC475 Projector Lens Replacement: 5 단계, 이미지 1/2 Electrohome EAAC475 Projector Lens Replacement: 5 단계, 이미지 2/2
    • Unplug the projector's connector from the circuit board.
  6. Electrohome EAAC475 Projector Lens Replacement: 6 단계, 이미지 1/1
    • Take off the rubber ring.
  7. Electrohome EAAC475 Projector Lens Replacement: 7 단계, 이미지 1/3 Electrohome EAAC475 Projector Lens Replacement: 7 단계, 이미지 2/3 Electrohome EAAC475 Projector Lens Replacement: 7 단계, 이미지 3/3
    • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
    • Slide the tool along the crease to separate.
  8. Electrohome EAAC475 Projector Lens Replacement: 8 단계, 이미지 1/1
    • Take the lens out of the projector.
  9. Electrohome EAAC475 Projector Lens Replacement: 9 단계, 이미지 1/1
    • Separate the lens and the gear by unscrewing the gear.
결론
Sterling Fulk
회원 가입일: 02/16/16
264 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016 회원
IUPUI-HARLEY-S16S2G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 348
