주요 콘텐츠로 건너뛰기
Elegoo Mars 3 Limit Switch Replacement
필요한 것
  1. Elegoo Mars 3 Limit Switch Replacement, Remove the back screws: 1 단계, 이미지 1/1
    • Remove 6 screws.
    • 12.5mm self tapping screws with 2.0mm hex socket head
  2. Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: 2 단계, 이미지 1/2 Elegoo Mars 3 Limit Switch Replacement, Remove the back lid: 2 단계, 이미지 2/2
    • Use a small flat-headed screwdriver, spudger, or similar to pry open the lid enough to be able to get a grip of it and pull straight back and then fold down.
    • The back of the lid has a PCB with cables connecting it to the motherboard inside the unit. While not particularly fragile, do take care so you do not damage the connectors.
  3. Elegoo Mars 3 Limit Switch Replacement, Unplug the cable for the limit switch: 3 단계, 이미지 1/1
    • In my case the replacement limit switch was delivered already connected to a cable. If you are only replacing the actual switch you can skip this step and instead unplug the opposing end on the switch itself later..
    • Remove the limit switch cable connector in the bottom right corner by pulling it straight out.
    • Be sure to pull the connector, and not the cables!
  4. Elegoo Mars 3 Limit Switch Replacement: 4 단계, 이미지 1/3 Elegoo Mars 3 Limit Switch Replacement: 4 단계, 이미지 2/3 Elegoo Mars 3 Limit Switch Replacement: 4 단계, 이미지 3/3
    • Remove the two screws securing the limit switch.
    • M4x7.5mm socket screw with 2.5mm hex socket head
    • Hold the limit switch in the lower end and pull it downwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Konrad Skeri Ekblad
회원 가입일: 12/10/17
520 평판
안내서 3개 작성하였습니다
댓글 2개
I've looked everywhere and can't seem to find a place to buy a replacement limit switch. Any suggestions?
johnathan cuda - 답글
I got my replacement directly from Elegoo support. Send them an email, they are very helpful.
Konrad Skeri Ekblad -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 28
전체 시간: 682
