이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This simple five-step guide will show you how to replace your Element GC-1020's display.
필요한 것
Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
Unscrew the visible Philips head screws (size: 3.968 mm) on the motherboard located on the top of left and right sides. Use a PH #0 sized screw driver head for removal.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
but can i ask do you know how to reboot the software ?
i mean we try to put in our music or video or image inside. can it be done
