주요 콘텐츠로 건너뛰기
Element GC-1020 Screen Replacement
필요한 것
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: 1 단계, 이미지 1/1
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Screen  Replacement: 2 단계, 이미지 1/1
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Screen  Replacement, Screen: 3 단계, 이미지 1/1
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
  4. Element GC-1020 Screen  Replacement: 4 단계, 이미지 1/2 Element GC-1020 Screen  Replacement: 4 단계, 이미지 2/2
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
  5. Element GC-1020 Screen  Replacement: 5 단계, 이미지 1/3 Element GC-1020 Screen  Replacement: 5 단계, 이미지 2/3 Element GC-1020 Screen  Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
  6. Element GC-1020 Screen  Replacement: 6 단계, 이미지 1/3 Element GC-1020 Screen  Replacement: 6 단계, 이미지 2/3 Element GC-1020 Screen  Replacement: 6 단계, 이미지 3/3
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Lashaun Noel
회원 가입일: 09/25/15
591 평판
안내서 5개 작성하였습니다
University of Tampa, Team 1-4, Whiteside Fall 2015 University of Tampa, Team 1-4, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 18
전체 시간: 256
