주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Element GC-1020 Screen Replacement
필요한 것
  1. Element GC-1020 Screen  Replacement, Back Cover Replacement Guide: 1 단계, 이미지 1개 중 1개
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
    댓글 쓰기
  2. Element GC-1020 Screen  Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
    댓글 쓰기
  3. Element GC-1020 Screen  Replacement, Screen: 3 단계, 이미지 1개 중 1개
    • Unscrew the bottom of left and right sides of the motherboard.
    • Notice these screws are slightly larger than the ones on the outside of the device.
    댓글 쓰기
  4. Element GC-1020 Screen  Replacement: 4 단계, 이미지 2개 중 1개 Element GC-1020 Screen  Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully bend the plastic frame to remove the motherboard.
    • Be sure that the power button, stays attached to the outer frame, as moving the motherboard it may cause it to loosen.
    댓글 쓰기
  5. Element GC-1020 Screen  Replacement: 5 단계, 이미지 3개 중 1개 Element GC-1020 Screen  Replacement: 5 단계, 이미지 3개 중 2개 Element GC-1020 Screen  Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Detach the screen by disconnecting the thin piece of ribbon cable attached to the PCB (printed circuit board).
    • Use a pair of tweezers to carefully pull the ribbon from the circuit board.
    • Take care not to damage the ribbon, as you will need it intact to reattach your new screen.
    댓글 쓰기
  6. Element GC-1020 Screen  Replacement: 6 단계, 이미지 3개 중 1개 Element GC-1020 Screen  Replacement: 6 단계, 이미지 3개 중 2개 Element GC-1020 Screen  Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully pry apart the screen from the frame of the device.
    • Separate the two by peeling away the thin plastic layer that makes up the screen of the device.
    • If done correctly, your detached screen will look like this.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Lashaun Noel
회원 가입일: 09/25/15
591 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 33
전체 시간: 563
