주요 콘텐츠로 건너뛰기
Elenco Auto-Scan FM Radio Model FM-88K Capacitor 22 Replacement
필요한 것
    • Remove the battery and the antenna.
    • Pre-heat the soldering iron.
    • Place hot solder iron on thermal pad, capacitor lead, and the mound of solder until solder liquefies.
    • Apply desoldering pump to remove the solder from the circuit board.
    • Repeat the instructions to remove solder from the adjacent solder mound.
    • Gently remove the capacitor by pulling the two leads out of the circuit board.
    • Place the leads of the capacitor through designated holes of the circuit board.
    • Place solder iron on the thermal pad and the lead.
    • Once this is done wait a few seconds until both items heat up.
    • Once they are heated, apply the solder to the other side so that the solder iron and the solder are not directly touching.
    • Wait 3 to 5 seconds or until enough solder covers the whole pad and forms a nice mound.
    • Remove the solder, leaving the solder iron on the pad for 2 to three seconds, then remove the solder iron.
    • Repeat for the other lead.
    • Plug the battery in and attach the antenna to test the radio.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Charles Riel
회원 가입일: 10/10/14
218 평판
안내서 1개 작성함
Charlie Riel Charlie Riel 회원
Community
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 20
전체 시간: 1,049
