소개
If your battery is no longer charging or holding a charge you may need to replace it, in this guide you will learn exactly how to replace the battery in your tablet.
필요한 것
There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
이 단계에 사용된 도구:Plastic Cards$2.99
4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
