주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
If your front facing camera is no longer working or if your camera lens is cracked then you may need to replace it, this guide with teach you exactly how to replace your tablets front facing camera.
  1. There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose. Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Once you pry off the plastic backing, you will expose the battery and the motherboard.
    • Once you pry off the plastic backing, you will expose the battery and the motherboard.
  4. carefully pry off the plastic backing, remove the tape over the camera. When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
    • carefully pry off the plastic backing, remove the tape over the camera.
    • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
  5. Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape. Gently lift up the black lever that’s holding the camera ribbon in place using the spudger tools.
    • Carefully remove the tape holding the camera in place as the camera is attached to the backing of the tape.
    • Gently lift up the black lever that’s holding the camera ribbon in place using the spudger tools.
    • Once lever is lifted up, remove camera from device; and it is ready to be replaced.
결론
Jonathan Scinto
회원 가입일: 2015년 07월 21일
515 평판
안내서 4개 작성하였습니다
Eastern Washington University, Team 1-1, Rowley SU 2015 Eastern Washington University, Team 1-1, Rowley SU 2015 회원
EWU-ROWLEY-SU15S1G1
4 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 192
