주요 콘텐츠로 건너뛰기
Ematic FunTab 3 Back Panel Replacement
필요한 것
  1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: 1 단계, 이미지 1/3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: 1 단계, 이미지 2/3 Ematic FunTab 3 Back Panel  Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Back Panel  Replacement: 2 단계, 이미지 1/1
    • Pull the back panel away from the screen.
결론
Harrison Lee
회원 가입일: 07/12/18
85 평판
안내서 1개 작성함
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G5
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 196
