주요 콘텐츠로 건너뛰기
Ematic FunTab 3 Camera Replacement
필요한 것
  1. Ematic FunTab 3 Camera Replacement, Back Panel: 1 단계, 이미지 1/3 Ematic FunTab 3 Camera Replacement, Back Panel: 1 단계, 이미지 2/3 Ematic FunTab 3 Camera Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Camera Replacement: 2 단계, 이미지 1/1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Camera Replacement, Camera: 3 단계, 이미지 1/2 Ematic FunTab 3 Camera Replacement, Camera: 3 단계, 이미지 2/2
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Camera Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to flip up the black retaining tab.
  5. Ematic FunTab 3 Camera Replacement: 5 단계, 이미지 1/2 Ematic FunTab 3 Camera Replacement: 5 단계, 이미지 2/2
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
결론
Amanda Davis
회원 가입일: 07/11/18
581 평판
안내서 5개 작성하였습니다
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G5
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 152
