주요 콘텐츠로 건너뛰기
Ematic FunTab 3 Touch Screen Replacement
필요한 것
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Touch Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Remove the black tape to reveal the screen connector.
  4. Ematic FunTab 3 Touch Screen Replacement: 4 단계, 이미지 2개 중 1개 Ematic FunTab 3 Touch Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
  5. Ematic FunTab 3 Touch Screen Replacement: 5 단계, 이미지 2개 중 1개 Ematic FunTab 3 Touch Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
  6. Ematic FunTab 3 Touch Screen Replacement: 6 단계, 이미지 1개 중 1개
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 7 단계, 이미지 2개 중 1개 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 7 단계, 이미지 2개 중 2개
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
  8. Ematic FunTab 3 Touch Screen Replacement: 8 단계, 이미지 1개 중 1개
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
결론
작성자
3다른 기여자 명과 함께
Amanda Davis
회원 가입일: 07/11/18
581 평판
안내서 5개를 작성함
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G5
4 회원들
안내서 12개를 작성함
1가이드 댓글
Where can I get a new display for my emoticons funtab 3?
DanTheMan RBLX - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 1,024
