주요 콘텐츠로 건너뛰기
Ematic Funtab FTABXXX Camera Replacement
필요한 것
  1. Ematic Funtab FTABXXX Camera Replacement, Camera: 1 단계, 이미지 1/2 Ematic Funtab FTABXXX Camera Replacement, Camera: 1 단계, 이미지 2/2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Camera Replacement: 2 단계, 이미지 1/2 Ematic Funtab FTABXXX Camera Replacement: 2 단계, 이미지 2/2
    • Locate the camera in the top of the device. Note the plastic clip holding it in place.
  3. Ematic Funtab FTABXXX Camera Replacement: 3 단계, 이미지 1/1
    • Carefully remove the white clip holding the camera.
    • Carefully lift the data cable connecting the camera to the device's motherboard.
  4. Ematic Funtab FTABXXX Camera Replacement: 4 단계, 이미지 1/1
    • Take the new camera piece and insert the data cable connection into the connection.
결론
Dustin Clark
회원 가입일: 01/21/15
197 평판
안내서 1개 작성함
USF Tampa, Team 6-3, Brown Winter 2015 USF Tampa, Team 6-3, Brown Winter 2015 회원
USFT-BROWN-W15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 130
