주요 콘텐츠로 건너뛰기
Ematic Funtab FTABXXX Power and Sound Buttons Replacement
필요한 것
  1. Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: 1 단계, 이미지 1/2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement, Power and Sound Buttons: 1 단계, 이미지 2/2
    • Before opening the device make sure the device is powered down if possible.
    • Using a spading tool open the device along the clips.
  2. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 2 단계, 이미지 1/2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 2 단계, 이미지 2/2
    • Locate the plastic power button.
    • Locate the plastic sound button.
  3. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 3 단계, 이미지 1/1
    • Once the power button has been located place it in the appropriate spot as indicated by the picture. Make sure that the plastic button will connect with the black button when pressed.
  4. Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 4 단계, 이미지 1/2 Ematic Funtab FTABXXX Power and Sound Buttons Replacement: 4 단계, 이미지 2/2
    • Once the sound button has been located place it in the correct spot as indicated by the picture.
    • Make sure the plastic sound button will connect with the small black buttons when pressed down.
결론
Xavier Smith
회원 가입일: 01/21/15
210 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-3, Brown Winter 2015 USF Tampa, Team 6-3, Brown Winter 2015 회원
USFT-BROWN-W15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 307
