주요 콘텐츠로 건너뛰기
Ematic Funtab FTABXXX Speaker Replacement
필요한 것
  1. Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: 1 단계, 이미지 1/2 Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: 1 단계, 이미지 2/2
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Speaker Replacement, Locating the speaker: 2 단계, 이미지 1/1
    • Locate the speaker in the bottom right hand side of the device. Note the red and black wires attaching the speaker to the motherboard.
  3. Ematic Funtab FTABXXX Speaker Replacement, Removing the old speaker: 3 단계, 이미지 1/1
    • Carefully remove the soldered wires from the motherboard. Note the positive and negative symbol where the red and black wires are soldered to on the motherboard.
  4. Ematic Funtab FTABXXX Speaker Replacement, Soldering the new speaker: 4 단계, 이미지 1/1
    • Carefully, solder the new speaker wires to the motherboard in the same fashion as the old speaker. The red wire to the '+' symbol and the black wire to the '-' symbol.
  5. Ematic Funtab FTABXXX Speaker Replacement, Positioning the speaker: 5 단계, 이미지 1/1
    • Once the solder points have cooled, position the speaker into the speaker housing on the back bezel as shown in the image.
결론
Robert Zarobinski
회원 가입일: 01/21/15
269 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-3, Brown Winter 2015 USF Tampa, Team 6-3, Brown Winter 2015 회원
USFT-BROWN-W15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 163
