주요 콘텐츠로 건너뛰기
Ematic Genesis 2 Audio Jack Repair
필요한 것
  1. Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: 1 단계, 이미지 1/2 Ematic Genesis 2 Audio Jack Repair, Ematic Genesis 2 Audio Jack Repair: 1 단계, 이미지 2/2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Audio Jack Repair: 2 단계, 이미지 1/3 Ematic Genesis 2 Audio Jack Repair: 2 단계, 이미지 2/3 Ematic Genesis 2 Audio Jack Repair: 2 단계, 이미지 3/3
    • Remove all four screws surrounding the battery with the screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Audio Jack Repair: 3 단계, 이미지 1/1
    • Remove the two screws that hold the audio jack in place. Carefully lift the audio jack out of the compartment.
    • Use compressed air or a Q-tip to gently clear out the dirt from the inside of the audio jack. This will help make sure future connections are clear.
결론
Taylor Beauchemin
회원 가입일: 08/26/15
113 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 151
