주요 콘텐츠로 건너뛰기
Ematic Genesis 2 Battery Replacement
필요한 것
  1. Ematic Genesis 2 Battery Replacement, Battery: 1 단계, 이미지 1/2 Ematic Genesis 2 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Battery Replacement: 2 단계, 이미지 1/3 Ematic Genesis 2 Battery Replacement: 2 단계, 이미지 2/3 Ematic Genesis 2 Battery Replacement: 2 단계, 이미지 3/3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Battery Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
    • When using the soldering iron to heat the existing solder, do not damage the device or surrounding connections.
    • Once all solder is gone, remove the wires from the device to free the battery.
  4. Ematic Genesis 2 Battery Replacement: 4 단계, 이미지 1/1
    • Use the soldering iron to solder the wires from the new battery to the device.
    • The connections from the wires should go in order from left to right being white, black (negative), and red (positive), respectively.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Key
회원 가입일: 08/26/15
246 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 344
