소개
This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
필요한 것
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
이 단계에 사용된 도구:Desoldering Pump$3.99
Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
Once all solder is gone, remove the wires from the device to free the battery.
다른 2명이 해당 안내서를 완성하였습니다.
