주요 콘텐츠로 건너뛰기
Ematic Genesis 2 Charging Port Replacement
필요한 것
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/2 Ematic Genesis 2 Charging Port Replacement, Charging Port: 1 단계, 이미지 2/2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: 2 단계, 이미지 1/3 Ematic Genesis 2 Charging Port Replacement: 2 단계, 이미지 2/3 Ematic Genesis 2 Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: 3 단계, 이미지 1/2 Ematic Genesis 2 Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: 4 단계, 이미지 1/2 Ematic Genesis 2 Charging Port Replacement: 4 단계, 이미지 2/2
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: 5 단계, 이미지 1/2 Ematic Genesis 2 Charging Port Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: 6 단계, 이미지 1/1
    • Solder replacement port into place.
    • Make sure all connections match original.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexandria Ehrnsberger
회원 가입일: 08/26/15
137 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 544
