주요 콘텐츠로 건너뛰기
Ematic Genesis 2 Screen Replacement
필요한 것
  1. Ematic Genesis 2 Screen Replacement, Screen: 1 단계, 이미지 1/2 Ematic Genesis 2 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: 2 단계, 이미지 1/3 Ematic Genesis 2 Screen Replacement: 2 단계, 이미지 2/3 Ematic Genesis 2 Screen Replacement: 2 단계, 이미지 3/3
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: 3 단계, 이미지 1/2 Ematic Genesis 2 Screen Replacement: 3 단계, 이미지 2/2
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: 4 단계, 이미지 1/1
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: 5 단계, 이미지 1/1
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
결론
Brandon Key
회원 가입일: 08/26/15
246 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 439
