주요 콘텐츠로 건너뛰기
Ematic Model FTABMP2 Case Replacement
필요한 것
  1. Ematic Model FTABMP2 Case Replacement, Case: 1 단계, 이미지 1/2 Ematic Model FTABMP2 Case Replacement, Case: 1 단계, 이미지 2/2
    • Use a spudger to pry open the case of your device to reveal the inside.
  2. Ematic Model FTABMP2 Case Replacement: 2 단계, 이미지 1/2 Ematic Model FTABMP2 Case Replacement: 2 단계, 이미지 2/2
    • Disconnect the LCD cable from the motherboard by pressing together the two sides of the clamp to separate the device into two.
  3. Ematic Model FTABMP2 Case Replacement: 3 단계, 이미지 1/1
    • Use the spudger to pry the LCD from the clamps holding it to the case.
  4. Ematic Model FTABMP2 Case Replacement: 4 단계, 이미지 1/2 Ematic Model FTABMP2 Case Replacement: 4 단계, 이미지 2/2
    • If you need to remove the back part of the casing, after disconnecting the LCD display from the motherboard, remove the screws holding down the motherboard. Remove the plastic power and volume buttons. remove the two side grips of the device.
  5. Ematic Model FTABMP2 Case Replacement: 5 단계, 이미지 1/2 Ematic Model FTABMP2 Case Replacement: 5 단계, 이미지 2/2
    • Remove the motherboard, speaker, and battery as a whole, which leaves just the back casing of the device.
결론
Timothy
회원 가입일: 01/21/15
505 평판
안내서 5개 작성하였습니다
USF Tampa, Team 9-2, Brown Winter 2015 USF Tampa, Team 9-2, Brown Winter 2015 회원
USFT-BROWN-W15S9G2
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 168
