소개
This replacement guide will help you replace a broken or cracked screen on the Emetic eGlide 4 to ensure maximum viewing capabilities. The screen is attached to the front case as well as the motherboard. The other electrical components of the device must be removed prior to removing the screen. The screen is then removed from the front case, and then the screen's circuit board is disconnected from the mother board.
필요한 것
Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger.
Remove the gold ribbon wire from the ribbon wire port on the motherboard.
