주요 콘텐츠로 건너뛰기
Ematic eGlide 4 Side Button Array Replacement
필요한 것
  1. Ematic eGlide 4 Side Button Array Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Side Button Array Replacement: 2 단계, 이미지 1/1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Side Button Array Replacement: 3 단계, 이미지 1/2 Ematic eGlide 4 Side Button Array Replacement: 3 단계, 이미지 2/2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Side Button Array Replacement, Side Button Array: 4 단계, 이미지 1/1
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Side Button Array Replacement: 5 단계, 이미지 1/2 Ematic eGlide 4 Side Button Array Replacement: 5 단계, 이미지 2/2
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Side Button Array Replacement: 6 단계, 이미지 1/1
    • Remove the side button array from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bailey Hughes
회원 가입일: 03/22/15
617 평판
안내서 6개 작성하였습니다
Baylor, Team 5-8, Williams Spring 2015 Baylor, Team 5-8, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G8
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 98
