주요 콘텐츠로 건너뛰기
Ember Mug Charging Base Pogo Pins Replacement
필요한 것
  1. Ember Mug Charging Base Pogo Pins Replacement, The Charging Base: 1 단계, 이미지 1/1
    • The charging base has two spring contacts, also called pogo pins, that transfer power from the charging base to the mug.
    • Over time or due to liquid exposure, the contacts can oxidize or lose their ability to spring back up, resulting in a loss of contact and thus failure to charge the mug.
  2. Ember Mug Charging Base Pogo Pins Replacement, Remove the Retaining Screw: 2 단계, 이미지 1/3 Ember Mug Charging Base Pogo Pins Replacement, Remove the Retaining Screw: 2 단계, 이미지 2/3 Ember Mug Charging Base Pogo Pins Replacement, Remove the Retaining Screw: 2 단계, 이미지 3/3
    • The rubber base on the bottom of the charging plate covers a Torx screw that must be removed to open up the plate.
    • Peel back the base far enough to expose the Torx screw.
    • Using a T8 Torx driver, remove the single retaining screw.
  3. Ember Mug Charging Base Pogo Pins Replacement, Open the Base: 3 단계, 이미지 1/2 Ember Mug Charging Base Pogo Pins Replacement, Open the Base: 3 단계, 이미지 2/2
    • Use a metal pry tool such as the iSesamo inserted into the seam between the metal top and the plastic base to open it up.
  4. Ember Mug Charging Base Pogo Pins Replacement, Dismount the Circuit Board: 4 단계, 이미지 1/3 Ember Mug Charging Base Pogo Pins Replacement, Dismount the Circuit Board: 4 단계, 이미지 2/3 Ember Mug Charging Base Pogo Pins Replacement, Dismount the Circuit Board: 4 단계, 이미지 3/3
    • Here we see the two halves separated, but connected by wiring.
    • The circuit board is held on with adhesive. Use your pry tool to gently separate the circuit board from the plastic mounting block it sits on.
    • During reassembly, make sure the cutout in the plastic base sits correctly over the circuit board.
  5. Ember Mug Charging Base Pogo Pins Replacement, About the Pins: 5 단계, 이미지 1/3 Ember Mug Charging Base Pogo Pins Replacement, About the Pins: 5 단계, 이미지 2/3 Ember Mug Charging Base Pogo Pins Replacement, About the Pins: 5 단계, 이미지 3/3
    • Here you can see a closeup of the pin with the failed spring on the right vs. the functional pin on the left
    • The pins are approximately 4.5 mm in height on this particular model.
    • Here is the replacement pin placed next to the originals. So far, so good.
  6. Ember Mug Charging Base Pogo Pins Replacement, Remove the Old Pin(s): 6 단계, 이미지 1/3 Ember Mug Charging Base Pogo Pins Replacement, Remove the Old Pin(s): 6 단계, 이미지 2/3 Ember Mug Charging Base Pogo Pins Replacement, Remove the Old Pin(s): 6 단계, 이미지 3/3
    • Apply flux and unsolder the defective pin or pins.
  7. Ember Mug Charging Base Pogo Pins Replacement, Solder in the Replacement Pin(s): 7 단계, 이미지 1/2 Ember Mug Charging Base Pogo Pins Replacement, Solder in the Replacement Pin(s): 7 단계, 이미지 2/2
    • Tin the replacement pin.
  8. Ember Mug Charging Base Pogo Pins Replacement: 8 단계, 이미지 1/2 Ember Mug Charging Base Pogo Pins Replacement: 8 단계, 이미지 2/2
    • Using the minimum amount of solder, solder the new pin in place.
  9. Ember Mug Charging Base Pogo Pins Replacement, Add Adhesive: 9 단계, 이미지 1/3 Ember Mug Charging Base Pogo Pins Replacement, Add Adhesive: 9 단계, 이미지 2/3 Ember Mug Charging Base Pogo Pins Replacement, Add Adhesive: 9 단계, 이미지 3/3
    • The adhesive keeps the parts together, but also provides a modicum of waterproofing.
    • I chose iPhone battery adhesive as it appears to be very similar to the original adhesive found on the charging plate.
  10. Ember Mug Charging Base Pogo Pins Replacement, Reassemble: 10 단계, 이미지 1/1
    • Stick the circuit board onto the black plastic mounting pad.
  11. Ember Mug Charging Base Pogo Pins Replacement: 11 단계, 이미지 1/1
    • Reassembled with the new pin in place.
  12. Ember Mug Charging Base Pogo Pins Replacement, Test: 12 단계, 이미지 1/1
    • Final step, place the mug on the charging base.
    • Success, we have a charging light once again!
결론
While the replacement pin from AliExpress wasn't a 100% exact match, it was certainly close enough to be fully functional so all in all, the repair was an unqualified success!
Note that I've added an eBay listing that purports to contain the correct pins for this charger, but I have not seen the kit so I cannot verify that information.
다른 6명이 해당 안내서를 완성하였습니다.
Jerry Wheeler
회원 가입일: 03/21/22
58,524 평판
안내서 69개 작성하였습니다
Oregonians Oregonians 회원
Community
8 회원들
안내서 176개 작성하였습니다
댓글 2개
Great guide Jerry! The only suggestion is that while the base is opened up and I have a bag of 10 new pogo pins (on their way from AliExpress), I will be replacing them both. It will only will take me another 2 minutes and also ensure the new pins are both protruding the exact same amount. The question is whether I will hang onto that "good" one that I didn't need to replace in the bag of 8 spare pogo pins. If you are a big DIY repair person, you will know this moral dilemma oh too well. ;-)
Chris Sosnowski - 답글
Entirely sound reasoning in my opinion; if one has failed, how far behind will the second one be? And as you say, you've got 10 of them, so it's not like you have to be stingy with them.
As someone who tends to hold onto things for too long (I finally donated the perfectly good iPhone 4's and 5's I had sitting in a box since Verizon will no longer allow 3G devices to be added to their network), I understand the temptation, but then again, you've got 8 brand new ones if you ever need another one, so what's the advantage to hanging on to a used one? Like that commercial about turning into your parents: When will you need it? Never - throw it away. :D
Jerry Wheeler -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 84
30일 전: 352
전체 시간: 1,674
