주요 콘텐츠로 건너뛰기
Emson Star Wars R2-D2 Humidifier Fan Replacement
필요한 것
  1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Remove the top cover of the humidifier by pulling upwards.
  2. Emson Star Wars R2-D2 Humidifier Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Grip the dial from the front of the device and gently pull it away to remove it.
  3. Emson Star Wars R2-D2 Humidifier Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the blue water tank of the humidifier by pulling upwards.
  4. Emson Star Wars R2-D2 Humidifier Fan Replacement: 4 단계, 이미지 2개 중 1개 Emson Star Wars R2-D2 Humidifier Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
  5. Emson Star Wars R2-D2 Humidifier Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the blue plastic top by pulling upwards on the middle notch.
  6. Emson Star Wars R2-D2 Humidifier Fan Replacement: 6 단계, 이미지 1개 중 1개
    • This is where the fan is located. Carefully remove the fan from its compartment.
    • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
    • Remove the screws on the printed circuit board using the same PH1 driver.
  7. Emson Star Wars R2-D2 Humidifier Fan Replacement: 7 단계, 이미지 2개 중 1개 Emson Star Wars R2-D2 Humidifier Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Yash Chari
회원 가입일: 02/15/17
240 평판
안내서 2개를 작성함
USF Tampa, Team 8-5, Eyestone Spring 2017 USF Tampa, Team 8-5, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S8G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 892
