이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Grip the dial from the front of the device and gently pull it away to remove it.
Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
This is where the fan is located. Carefully remove the fan from its compartment.
Remove the screws on the printed circuit board using the same PH1 driver.
Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
다른 4명이 해당 안내서를 완성하였습니다.
